Ok guys started removing my box to say ready for clutch tomorrow. And I can't get the bolt to budge on the rear gear box mount at all l ( I'm on axel stands so leverage is abit of a issue). Now I was looking at the mount and it appears to be attached to the car with 4 big bolts would I be able to remove them plus exhaust and that anti roll bar thing?? Would that work or anyone done that before? Many thanks.
Nooe ratchet with a pole over the handle lol. Bot I think the for holding it to the car will be easier lol. Just means exhaust n that bar has to come out.
just take the long 14mm bolt out goes through bracket for rear mount when ya have all the box bolts out give it a slight pull box will pull away from engine and twist box backwards should come out easy enough
this !
