Gearbox mount problems. Glanza
Ok guys started removing my box to say ready for clutch tomorrow. And I can't get the bolt to budge on the rear gear box mount at all l ( I'm on axel stands so leverage is abit of a issue). Now I was looking at the mount and it appears to be attached to the car with 4 big bolts would I be able to remove them plus exhaust and that anti roll bar thing?? Would that work or anyone done that before? Many thanks.
just take the long 14mm bolt out goes through bracket for rear mount when ya have all the box bolts out give it a slight pull box will pull away from engine and twist box backwards should come out easy enough
this !
