I got a set of brand new lucas high imp 440cc injectors for my charade £110. Available from the US, mustang injectors. Would need different plugs
  • 1 month later...
I've got a very similar set up to this and I've been advise today that it would be wise to upgrade my injectors as they will be pushing their limits on around 1bar. For the extra couple of hundred quid, I'd just do it rather than risk anything.
Although not much need for new injectors for stock turbo, if you want to really upgrade, get at least the newer style (slim plastic body) injectors.
RX8 red are 350ish and RX8 yellow are 430ish and usually cheap in the breakers.
I've never new what size the Reds were for sure, but I've a set here if anyone wants to make an offer.
Also you will be wanting bigger injectors mainly cause methanol/ethanol will up your required flow significantly.
But give big benefits on a turbo that could be running hot, only way I'd see someone making decent power on a ct9 frame would be with better fuel.
I'd suggest bioethanol
Phil
