nikhilkamdar12 Posted July 27, 2016 Share Posted July 27, 2016 Hi all, After a new original drive shaft nut for the Glanza. Don't know if I'm being blind but looked on the parts site and can't seem to find it?... http://japan-parts.eu/toyota/jp/1999/starlet/ep91-agmqy/4_121150_006_/powertrain-chassis/4302_front-drive-shaft Does anyone know the part number so I can order it from Toyota? Thanks Quote Link to post Share on other sites
Starlet__SR Posted July 27, 2016 Share Posted July 27, 2016 Same as a uk starlet. Quote Link to post Share on other sites
Starlet__SR Posted July 27, 2016 Share Posted July 27, 2016 http://japan-parts.eu/toyota/jp/1999/starlet/ep91-agmqy/4_121150_006_/powertrain-chassis/4303_front-axle-hub Quote Link to post Share on other sites
nikhilkamdar12 Posted July 27, 2016 Author Share Posted July 27, 2016 http://japan-parts.eu/toyota/jp/1999/starlet/ep91-agmqy/4_121150_006_/powertrain-chassis/4303_front-axle-hub Legend...yep was being blind! Quote Link to post Share on other sites
sseabass Posted August 6, 2016 Share Posted August 6, 2016 Does anyone have the torque setting for the wheel bearing nuts, I need both front and back. I have EP91 1998Thanks in advance. Quote Link to post Share on other sites
roachburger Posted August 6, 2016 Share Posted August 6, 2016 Fronts are 216nmRears are taper bearings. Just go for a good 1/2" ratchet till tight then back them off and just nip them up a tiny bit more than hand tight ...dont overtighten the rears, if you do the rear wheels will lock solid about a mile up the road.i have photos of the results. Quote Link to post Share on other sites
sseabass Posted April 6, 2020 Share Posted April 6, 2020 I did them to 200nm, close enough. Good to be sure. thanks. Quote Link to post Share on other sites
