nikhilkamdar12 Posted July 27, 2016 Posted July 27, 2016 Hi all, After a new original drive shaft nut for the Glanza. Don't know if I'm being blind but looked on the parts site and can't seem to find it?... http://japan-parts.eu/toyota/jp/1999/starlet/ep91-agmqy/4_121150_006_/powertrain-chassis/4302_front-drive-shaft Does anyone know the part number so I can order it from Toyota? Thanks Quote
Starlet__SR Posted July 27, 2016 Posted July 27, 2016 http://japan-parts.eu/toyota/jp/1999/starlet/ep91-agmqy/4_121150_006_/powertrain-chassis/4303_front-axle-hub Quote
nikhilkamdar12 Posted July 27, 2016 Author Posted July 27, 2016 http://japan-parts.eu/toyota/jp/1999/starlet/ep91-agmqy/4_121150_006_/powertrain-chassis/4303_front-axle-hub Legend...yep was being blind! Quote
sseabass Posted August 6, 2016 Posted August 6, 2016 Does anyone have the torque setting for the wheel bearing nuts, I need both front and back. I have EP91 1998Thanks in advance. Quote
roachburger Posted August 6, 2016 Posted August 6, 2016 Fronts are 216nmRears are taper bearings. Just go for a good 1/2" ratchet till tight then back them off and just nip them up a tiny bit more than hand tight ...dont overtighten the rears, if you do the rear wheels will lock solid about a mile up the road.i have photos of the results. Quote
sseabass Posted April 6, 2020 Posted April 6, 2020 I did them to 200nm, close enough. Good to be sure. thanks. Quote
