Hello All, I am puzzled by a problem that cropped up yesterday at night.I am having a problem with the left indicator function and horn.Anytime I indicate left the system blows the fuse,the same happens when i press the hazard indicator.I replaced the fuse to test and noted that indicating right does not blow the fuse.The left indicate function blows a fuse at the fuse box below the steering column which is rated at 7.5 A or a 15A at the engine bay.The 15A affects the horn.What could be the problem ?????
I had a thorough check on Wednesday and i didn't find a short circuit , what i noted is that i had to press the front left indicator bulb for it to work, I tested the system for a couple of times and all was well.I tried to clean the socket contacts and i was happy to have fixed the problem.
FFWD..... this morning i hopped into the vehicle and the indicators were not working again infact the fuse had blown and now all the indicators/hazard + horn are not functional.I think its time for me to visit a pro on this since its now beyond me.Very frustrating.
