onnaj1000 Posted August 3, 2016 Posted August 3, 2016 Hi,I have a ep71 1.3 XL with a Haslbeck body kit. Will post a project page later on.There are now AP springs mounted i think which should lower 40 mm but they seem to lower 50-60. That In combination with that body kit makes it too low especially when I'm going to mount my Ronal Turbos wheels with 195/45/15 wheels which have 1.1 cm less high as the 155/80/13 I have on now.Therefore I'd really like to buy 25 mm lowering springs or 30 mm at max. Is there anything available?Thanks Quote
MR-2 Posted August 4, 2016 Posted August 4, 2016 Rear is so light that I don't that will never drop 50-60mm compared to oem springs and schocks. Front maybe lower more than rear. Where have You found so much lowering spings? Quote
onnaj1000 Posted August 4, 2016 Author Posted August 4, 2016 Rear is so light that I don't that will never drop 50-60mm compared to oem springs and schocks. Front maybe lower more than rear. Where have You found so much lowering spings? Hi, I'm not sure they lower 50-60. They should lower 40 (brand is AP) but i think it's a tad more. Maybe it looks while it has a little bigger then stock tires (155/80/13). But i'm hitting bumps easily and next week i'm going to mount some Ronal Turbos with 195/45/15 tires, so that would lower the car an additional 10 mm. Here are some pictures of how the car looks at the moment: Quote
MR-2 Posted August 4, 2016 Posted August 4, 2016 Nice P7 Your spings or shocks are not in good condition or You have allready lowering springs, most of P7 are tractors. I think 25-30mm lowering springs are most common, never seen bigger mm as new. Consider coilovers, can adjust much better riding height, but needs big moneys, lowering springs are estimated 100-200 euros. Oem 13" wheels are so small anyway, looks horrible, I have now ones in my car What offset are those Ronals and how wide? Quote
MR-2 Posted August 4, 2016 Posted August 4, 2016 And this with newer rear shocks and old springs, front with VW coilovers, so ugly Quote
richardc9052 Posted August 4, 2016 Posted August 4, 2016 He already has lowering springs but they are too low. Quote
onnaj1000 Posted August 4, 2016 Author Posted August 4, 2016 Nice P7 Your spings or shocks are not in good condition or You have allready lowering springs, most of P7 are tractors. I think 25-30mm lowering springs are most common, never seen bigger mm as new. Consider coilovers, can adjust much better riding height, but needs big moneys, lowering springs are estimated 100-200 euros. Oem 13" wheels are so small anyway, looks horrible, I have now ones in my car What offset are those Ronals and how wide?Those Ronals are 7j and offset is 37 with 195/45 tires. Will be a tight fit I think with the lowering but should be possible Quote
morgey Posted August 4, 2016 Posted August 4, 2016 Dont know if ep7* spring are different to ep91 stuff but theres some 30mm springs for them here.http://www.demon-tweeks.co.uk/performance/lowering-springs/car/toyota/starlet-96-99/1998/1-3-ep91 Quote
onnaj1000 Posted August 4, 2016 Author Posted August 4, 2016 I did find some Kilen springs which are 30mm. Might give them a try Quote
