turbo-fever Posted August 10, 2016 Posted August 10, 2016 (edited) Are they any alloy 3/4 rads out there rather then half size ? I want as big as rad as possible but double thickness. A full size double thickness rad won't fit as it will hit the turbo so can I get 3/4 one ? Can I modify another one just move one of the rad hose points over Edited August 10, 2016 by turbo-fever Quote
daniel_g Posted August 10, 2016 Posted August 10, 2016 Never seen them.. but you could measure the space you have and have a scout about for an alloy rad that size.Or get a half size triple core civic rad. Quote
jayc-glanza17 Posted August 10, 2016 Posted August 10, 2016 Old polo rad i know has been used its in between civic rad and stock rad width wise.. unsure on thickness.I ended up going custom for mine.. not cheap but cools so well Quote
5e colin Posted August 10, 2016 Posted August 10, 2016 dont over kill it on the rad mate see al those tripple core civic rads being used there to cool single core or double no more really unless your going for track only Quote
gorganl2000 Posted August 11, 2016 Posted August 11, 2016 i think there is a radiator from some of the n/a starlets that is few inches shorter length wise than the gt/glanza radiator?!?! its single core i ran one in the past....i actually used it as a pattern to make a custom double core radiator Quote
