epcashin Posted August 19, 2016 Posted August 19, 2016 Hi small fault one right side reverse light stuck on ? And other one doesn't work any ideas ? Quote
rob_bower Posted August 19, 2016 Posted August 19, 2016 Check the switch iirc it's mounted in the top of the gearbox. Quote
FMuscle Posted August 20, 2016 Posted August 20, 2016 Is it only when the key is ON? If so, check the switch for the right light, and check the left globe. If not, you might have a short to power between the switch and the lights. Quote
epcashin Posted August 20, 2016 Author Posted August 20, 2016 light is stuck on once i turn on the lightsleft side doesnt work and right side is stuck on ?il check plug on box now but dont think thats it Quote
morgey Posted August 20, 2016 Posted August 20, 2016 Is your side/tail light working on that side? Quote
5e colin Posted August 20, 2016 Posted August 20, 2016 (edited) unscrew the reverse switch on the box and test and do a short test on the system to the rear very simple system Edited August 20, 2016 by 5e colin Quote
epcashin Posted August 20, 2016 Author Posted August 20, 2016 side tail light works on both sidesjust unpluged the reverse switch and 1 light still stuck on ? Quote
morgey Posted August 20, 2016 Posted August 20, 2016 Has the wiring been fucked about with at all? Chopped and spliced? Just thinking someone might have tried to jdm the rear lights, on ep91s the fog light and side light can be wired in together so you have double rear lights. Only someones wired it into your reverse light by accident? Quote
JDMginge Posted August 25, 2016 Posted August 25, 2016 My mates gt had his reverse light on drivers side wired to the rear fog light switch for some reason could this be the same Quote
