JaseTheTaff Posted September 8, 2016 Share Posted September 8, 2016 (edited) Hey guys So I have a standard glanva V and I've got awful wheel wobble under harder braking. Warped discs seems to be the issue according to a few friends who are much more mechanically minded than me. So can anyone advise me on a good set of discs and also is this something I could do at home with a decent guide or am I better taking it to a garage? I don't have a lot of experience but I want to learn as much as I can but obviously messing around with the brakes isn't something I want to get wrong thanks all! Edited September 8, 2016 by JaseTheTaff Quote Link to post Share on other sites
morgey Posted September 8, 2016 Share Posted September 8, 2016 Discs are fairly straight forward. Loosen wheel nuts. Jack car up safelyRemove wheelUndo 2 17mm bolts on back of the caliper carriers Knock caliper off of discKnock disc offClean hub of any debris, dirt and grimePut a small film of copper grease on hub face to stop disc rusting to it in future. Clean new discs with alcohol or degreaser.Fit discIf doing pads aswell you will want a G clamp to push the piston back in on the caliper then fit new pads. Then its just a case of reversing the above steps.If youre not sure have a mate who knows what he/shes doing to watch over and help out Quote Link to post Share on other sites
Keri-WMS Posted September 8, 2016 Share Posted September 8, 2016 If you're suffering with warped discs then our "110%" heavy duty ones would be ideal, they have 10% thicker castings to make them stiffer and run cooler. http://www.ukstarletowners.com/topic/72471-discspads-for-toyota-calipers-inc-wms-110-heavy-duty/ Quote Link to post Share on other sites
JaseTheTaff Posted September 8, 2016 Author Share Posted September 8, 2016 Discs are fairly straight forward.Loosen wheel nuts.Jack car up safelyRemove wheelUndo 2 17mm bolts on back of the caliper carriersKnock caliper off of discKnock disc offClean hub of any debris, dirt and grimePut a small film of copper grease on hub face to stop disc rusting to it in future.Clean new discs with alcohol or degreaser.Fit discIf doing pads aswell you will want a G clamp to push the piston back in on the caliper then fit new pads.Then its just a case of reversing the above steps.If youre not sure have a mate who knows what he/shes doing to watch over and help out That's awesome mate! That's really helpful cheers man If you're suffering with warped discs then our "110%" heavy duty ones would be ideal, they have 10% thicker castings to make them stiffer and run cooler. http://www.ukstarletowners.com/topic/72471-discspads-for-toyota-calipers-inc-wms-110-heavy-duty/ Cheers mate I'll check them out Quote Link to post Share on other sites
