EP70-PT Posted September 12, 2016 Posted September 12, 2016 Well, there's only one spade on the OEM wheel so I'm guessing it's a single wire that has to be shorted??? How do Imake it work on my MOMO, it has two spades Quote
TrisK Posted September 12, 2016 Posted September 12, 2016 That's a live. It earths to the boss. So put one spade on horn button. With the other put a lead on a spade and earth it out Quote
EP70-PT Posted September 12, 2016 Author Posted September 12, 2016 Earth it to the boss kit?? Have to find somewhereto attach a wire Quote
patman Posted September 12, 2016 Posted September 12, 2016 Pics up mate please as I'm gonna be doing this soon never had a horn since momo fitted Quote
EP70-PT Posted September 12, 2016 Author Posted September 12, 2016 Will try it tommorow with some wire Quote
Bug679 Posted September 12, 2016 Posted September 12, 2016 just use a spade connection one end and one with a ring connection the other side about 6 inches long and put the bolt through the ring end for holding the hub on 5 min job and blow your horn like fuck Quote
EP70-PT Posted September 12, 2016 Author Posted September 12, 2016 Where do I bolt the ring end?? Quote
Bug679 Posted September 13, 2016 Posted September 13, 2016 inbetween the hub and wheel just put one of the bolts through the ring end job done Quote
EP70-PT Posted September 13, 2016 Author Posted September 13, 2016 (edited) I put a screw in a spare bolt hole and did a loop with the wire and soldered so it's a solid ring, put the screw through it and job done! Beep beep! Edited September 13, 2016 by EP70-PT Quote
