BMX-RIG Posted October 19, 2016 Posted October 19, 2016 (edited) Ive had my gearbox rebuilt and since its gone back together its very noisy/ clunky. It has a TRD lsd and before the rebuild it wasent noisy. The oil used was 75W-90. This was what was recommended on the original paperwork for it from TRD. Ive read things in various places that suggest changing the gearbox oil to lsd specific. Can anyone suggest what to use? Any input would be great. Thanks Edited October 19, 2016 by BMX-RIG Quote
Phil Posted October 19, 2016 Posted October 19, 2016 I'd run the redline shock proof stuff for synchro boxsPhil Quote
BMX-RIG Posted October 20, 2016 Author Posted October 20, 2016 I'd run the redline shock proof stuff for synchro boxsPhilThanks for that Phil, ill look into it Quote
Stu Posted October 21, 2016 Posted October 21, 2016 What sort of noise is it making? All the time or on decel? Is it a diff noise or gearset? Quote
BMX-RIG Posted October 21, 2016 Author Posted October 21, 2016 It's acceleration and deceleration and low speed cornering, ive read in various places that some diffs are noisy but sometimes it makes some strange noises which dont sound too great, when cornering you lose confidence with it, As said the box was rebuilt with new bearings, before the box made grinding noises when the clutch was engadged but the diff never clunked or made a noise, but since the rebuild the gears a silent and the diff is noisy?Thanks for your response Quote
Stu Posted October 21, 2016 Posted October 21, 2016 Yeah its certainly off putting when its making noise! Id go back to who built it and get them to take it for a drive. My guess is they havent set the preload on the diff bearings correctly and its a bit loose possibly. Did they pull the diff down as well? Quote
BMX-RIG Posted October 22, 2016 Author Posted October 22, 2016 Ill give that a go, from what i was aware they replaced the input and output shaft bearings? Im not too clued up on the internals of a gearbox, would they have taken the diff out? When they had the box they told me it was and lsd ect. Quote
Stu Posted October 25, 2016 Posted October 25, 2016 Ah ok, well its possible they havent worked out the preload on the bearings properly? If the bearings don't have enough preload they can be quite noisy. Quote
