Matthewep91v Posted October 20, 2016 Posted October 20, 2016 Hi guys and girls Just wanted some advise on how I would go about feeding my screamer pipe back into my exhaust.As the car is used as a daily the screamer is just starting to get alittle bit annoying. I run a buddy club spec 2 exhaust and that is way loud enough so the screamer just pushes it over the top.I have a TD04 WEPR ham horn kit on my 1996 ep91 glanza v.Any advice would be appreciated Cheers Quote
Starlet__SR Posted October 20, 2016 Posted October 20, 2016 You will lose power by rerouting it back into the exhaust. You'd need a custom screamer pipe to go from the wastegate, then either welding or flanging onto the downpipe. Quote
Matthewep91v Posted October 20, 2016 Author Posted October 20, 2016 Damn was hoping it would of been a bit simpler than that Quote
Starlet__SR Posted October 20, 2016 Posted October 20, 2016 Sacha might be able to supply a new screamer and decat. Either that or get somewhere local to fabricate something. Frankly its more hassle than its worth. My advice is man up and live with it lol. Quote
Matthewep91v Posted October 20, 2016 Author Posted October 20, 2016 Hahahahaha Lovely advice My other reason is the police love it too hahaha Quote
Ollieh17 Posted October 20, 2016 Posted October 20, 2016 With a large exhaust id wager it would make barely any difference to power. Not for a starlet but i have an arrangment that makes it easy to switch between external vented and reroutedMiddle section is removable then a blank fitted onto the downpipe. Quote
Matthewep91v Posted October 20, 2016 Author Posted October 20, 2016 That is a brilliant idea!!!I think I am going to get it re routed in but send it to wepr so see if they might be able to sort somthing out I want it doing properly Quote
Starlet__SR Posted October 20, 2016 Posted October 20, 2016 That is a brilliant idea!!!I think I am going to get it re routed in but send it to wepr so see if they might be able to sort somthing out I want it doing properlyIt won't be cheap. Be easier to buy a rerouted screamer pipe and decat from WEPR outright. Rather than sending yours over to be modified. At least then you can switch between setups. Quote
lukEp Posted October 21, 2016 Posted October 21, 2016 Have a removable custom baffle put on it..... for them summer day when you want to be heard. ;) Quote
