EP70-PT Posted October 28, 2016 Share Posted October 28, 2016 What do I need for the conversion? The N/A seats don't clip in like the Glanza ones, and there's a white plastic that N/A's don't have... What's the full hardware I need before getting them sent over? Quote Link to post Share on other sites
ryan lang Posted October 28, 2016 Share Posted October 28, 2016 if you have a set of long nose pliers you can just take the covers off the glanza seats and swap them with the n/a covers i did it with a set of GT seats in my ep91 n/a Quote Link to post Share on other sites
EP70-PT Posted October 28, 2016 Author Share Posted October 28, 2016 The 96 Glanza seats are one piece and N/A two piece so it won't work mate Quote Link to post Share on other sites
morgey Posted October 28, 2016 Share Posted October 28, 2016 Rear seats will fit. You need the plastic clips from the Glanza that push into the floor and remove the central hinge in the na and the backs will bolt in Quote Link to post Share on other sites
EP70-PT Posted October 28, 2016 Author Share Posted October 28, 2016 Thanks mate judt the answer I needed Quote Link to post Share on other sites
morgey Posted October 28, 2016 Share Posted October 28, 2016 No worries, im running glanza recaros and they all bolt/clip in so not an issue. If you wanted 40/60 split rear seats the you want 98spec glanza seats.All you will need is to stick the two bolts in where the na seats bolt on the vertical bit in front of the seats as i think that goes through to the underside of the car iirc Quote Link to post Share on other sites
