Full soft with plenty of travel be ideal for the road (northern Irish roads anyways)
Full hard in the dry in track
6clicks from full hard in the wet on track
Though have a play front and rear see what you fancy most
Tyres pressures totally dependant on tyre type and usuage
Phil
Edited by Phil
Why ask people tbh it your car set it up to how u want it
will take alot of time to figure out playing around with it,if i have a base value them i can work around that i would be easier
I tend to be about halfway on Meisters, softer in the front by a few clicks. 30psi all round on AD08R's
so the back should be set on a harder setting than the front i ll try that cheers
Phil
thanks
