Duduglanza Posted November 14, 2016 Share Posted November 14, 2016 Hi,I got the LC working on my glanza.. but no boost is building up. Not even 1psi. What you people are imputing in the settings? Anyone got it working a building some boost on LC? Quote Link to post Share on other sites
gorganl2000 Posted November 15, 2016 Share Posted November 15, 2016 you have to input some ignition retard to build boost.....BUT BE VERY CAREFUL...you can blow your engine VERY quickly with this feature 1) you have to set rpm signal type to "Ignition signal" 2) i'd advice you leave it alone,,,but if you must use it, then input some small ignition retard values at first in the "ignition adjustment" tab and then reduce those values very slowly....like -1, -2, -3, etc. till you get what you want....and watch how much boost it builds as you test each value....don't keep your car on LC for any extended period, as it will build very hot exhaust temps and cylinder pressure 3) maybe best when you have done all of this to just get your tuned map (afr and ignition) rechecked to make sure it doesn't affect anything and you are not running lean or detonating anywhere i'd also advice you don't try to impress your friends and people in car parks by just sitting on LC and spitting flames from your exhaust, as above, your engine can be destroyed in a matter of seconds---- melted pistons, bent rods, hole in block, etc http://www.toyotagtturbo.com/forums/showthread.php?18701-The-Official-EMU-Tuning-amp-prob-thread!-Launch-control-success-thanks-to-fur!/page3 read pages 1-3.....and the whole tread if you have time Quote Link to post Share on other sites
richardc9052 Posted November 15, 2016 Share Posted November 15, 2016 I used to pull 50 deg on my Det3 because race car Quote Link to post Share on other sites
