Mr 2jz Posted November 14, 2016 Share Posted November 14, 2016 Hi everyone, this is a really random question 😂 But can you put the clocks with a rev counter on, into a starlet which doesn't have a rev counter in? Does that make sense? So can you basically swap the clocks over? Thanks. Quote Link to post Share on other sites
ryan lang Posted November 14, 2016 Share Posted November 14, 2016 the toyota paseo dials can be wired in to fit. i have a set for sale if youre interested? ive got the plugs wired as they should be for it to work so you can either splice it into yours, or change your wires around to match the plugs that i will give you with the clocks Quote Link to post Share on other sites
adzy Posted November 14, 2016 Share Posted November 14, 2016 There is another model starlet that basicly plugs straight in with no modifying needed as far as I know, something tells me its the gls model but not 100% sure Quote Link to post Share on other sites
ryan lang Posted November 14, 2016 Share Posted November 14, 2016 i think the CD plugs in without wiring changes. but they dont look as good as the paseo dials Quote Link to post Share on other sites
Mr 2jz Posted November 14, 2016 Author Share Posted November 14, 2016 Cheers guys, appreciate the help, reason being I've got an SR but it's been shunted up the arse so I plan on breaking it. Buying another and then swapping bits over as need be. Ideally want another SR but if not it'll be a normal starlet. If I end up down stock starlet route I'll give you a shout and have the clocks Ryan Quote Link to post Share on other sites
Starlet__SR Posted November 14, 2016 Share Posted November 14, 2016 GLS dials are a straight fit. Why not take the clocks out of the SR? Quote Link to post Share on other sites
westie Posted November 14, 2016 Share Posted November 14, 2016 There's a guide on here for swapping SR dials into a Sportif. I've used it and it works 100%. Quote Link to post Share on other sites
Mr 2jz Posted November 15, 2016 Author Share Posted November 15, 2016 I was just abit confused whether the rev counter would work being put in a car which doesn't have one, and is there? I'll have look. Trying to get another SR if I can, but if not it'll be going stock boring starlet route... Quote Link to post Share on other sites
