Gtbadboy2016 Posted November 24, 2016 Share Posted November 24, 2016 ... I took of my rear door pannels on my ep82 and realise it's rusty on the floor from the wheel arch all the way down im guessing to the end where the front door is. As I can not see even if I take the plastic trim off if that makes sense. Is there anyway of actually removing some part so I can get in there and sand it all down and spray it etc. Any help would be great. Thanks Aaron Quote Link to post Share on other sites
Ollieh17 Posted November 24, 2016 Share Posted November 24, 2016 The rust will probably need cutting out and replacing with new metal. Sounds like rusty sills Quote Link to post Share on other sites
enots Posted November 29, 2016 Share Posted November 29, 2016 Common area I've discovered myself for ep82 to start rotting. But nobody notices it unless it's stripped. As above replacing sills if it's bad is your only option Quote Link to post Share on other sites
fiddlersport Posted November 29, 2016 Share Posted November 29, 2016 I just did mine...mk3 fiesta sill or kaDepends how bad it is but very common on ep82 Quote Link to post Share on other sites
