M3mick Posted December 4, 2016 Posted December 4, 2016 Lads I've looked up and can't seem to find an answer!! Basically I've an ep91 glanza turbo automatic that needs lowering and prob callipers and few other chassis bits! I've found a ep82 turbo close by for cheap but just wondering which parts will fit!! Is the suspension brakes gearbox(I'll prob manual convert mine) all the same on both models I know the body work is different but don't need any of that so that's ok!! I know the exhaust needs a new hanger bracket just don't wanna go buying a car for parts if most of the parts don't fit! Cheers Quote
JamesD89 Posted December 4, 2016 Posted December 4, 2016 Most bits are interchangeable, brakes suspension etc. Manual box will bolt straight on too. Quote
gorganl2000 Posted December 5, 2016 Posted December 5, 2016 i did a manual conversion on my ep91 years ago using ep82 gt parts,,,most of the transmission parts are interchangeable...i hope someone can confirm, but i think some adjustment had to be done to the ep82 clutch pedal set up itself, as i recall i bought an ep91 specific clutch pedal set up later on sorry dude, this was a long time ago....over a decade, so memory of that time is now less clear Quote
