JarredsaintEP91 Posted December 9, 2016 Posted December 9, 2016 Hi guys been got this strange tapping noise on my glanza just wanna see if anyone can shine some light on this or have experienced the same noise and before anyone asksThe timing is okayThere is enough oil in thereDropped the sump and shells are all good Took the rocker cover off and nothing seems loose under there Video https://youtu.be/9RqE14seygcAlso the alternator bearing is very squeaky lol Quote
5e colin Posted December 9, 2016 Posted December 9, 2016 sounds like blown out gasket between turbo and mani Quote
SpikeyJp_68 Posted December 9, 2016 Posted December 9, 2016 sounds like blown out gasket between turbo and mani I thought myself it sounded a bit blowy but didn't want to fire out random suggestions haha Quote
MR-2 Posted December 9, 2016 Posted December 9, 2016 Never have this problem, suddenly tapping noise started and I was sure that my oilpump blewed, sound came belt area. Found that my lower plastic cover somehow was touching cranck alternator wheel or oilpump wheel. Pushed cover 1mm inside and sound was gone. After that some hot air blower and bended it inside little bit... Quote
MR-2 Posted December 10, 2016 Posted December 10, 2016 4E-FE engine, but exactly same sound as in Your video.Pushed zero dergees area, sound stopped Quote
akyakapotter Posted December 10, 2016 Posted December 10, 2016 Edited video link for you flower as I no your a little special Cheers nick. Quote
MR-2 Posted December 10, 2016 Posted December 10, 2016 Knock knock, maybe it is santaclaus came to your door too early, baddest choise :/ Or one valve fail is possible, locking nails popped out or snapped valve... Quote
JarredsaintEP91 Posted December 10, 2016 Author Posted December 10, 2016 Knock knock, maybe it is santaclaus came to your door too early, baddest choise :/ Or one valve fail is possible, locking nails popped out or snapped valve...Just my luck lol will check for what you've posted mate thanks for the comment 😃sounds like blown out gasket between turbo and mani Yeah I don't know which one it is lol I'll replace the lot Quote
