Sobshotta Posted December 16, 2016 Posted December 16, 2016 Hey guys I recently bought a ep82 currently stock running 10psi at the moment was wondering if a 3rd gen speedvision ct9 is worth it or should I try something else? Quote
Starlet__SR Posted December 16, 2016 Posted December 16, 2016 Aslong as it's a genuine speedvision and not one of the later chinese turbos. Quote
Sobshotta Posted December 16, 2016 Author Posted December 16, 2016 I actually came across one didn't know if it was any good ill post a linkhttps://www.amazon.com/gp/aw/d/B01H9XW418/ref=mp_s_a_1_13?ie=UTF8&qid=1481901352&sr=8-13&pi=AC_SX236_SY340_QL65&keywords=ct9+turboAlso any supporting mods you guys would recommend I also have a 2.5" fmic piping kt Quote
StuDoc 72 Posted December 16, 2016 Posted December 16, 2016 Try something no one else has done, like TD04. Quote
Sobshotta Posted December 16, 2016 Author Posted December 16, 2016 Try something no one else has done, like TD04.Tdo4 is pretty nice to be honest but I like the response of the ct9 was really curious to trying out the hybrid even though it costs quite abit Quote
Starlet__SR Posted December 16, 2016 Posted December 16, 2016 TF035 seems to be a middle ground between the CT9 and TD04 Quote
Sobshotta Posted December 16, 2016 Author Posted December 16, 2016 TF035 seems to be a middle ground between the CT9 and TD04Are they easy to find? Quote
samasaurasrex Posted December 16, 2016 Posted December 16, 2016 Are they easy to find? They're pretty easy to get hold of over here...not sure about Barbados lol. Just look for a Subaru forester thats being broke for parts, thats probably your best bet of getting one. Quote
amirs Posted December 16, 2016 Posted December 16, 2016 td04 is popular choice, depends on how much power you looking for. Quote
Sobshotta Posted December 16, 2016 Author Posted December 16, 2016 They have td04s here was wondering if I could run it without management for a bit Quote
samasaurasrex Posted December 16, 2016 Posted December 16, 2016 http://www.toyotagtturbo.com/forums/showthread.php?76641-A-comprehensive-list-of-parts-required-for-a-TD04-conversion. Have a look at this mate ^^^ Quote
5e colin Posted December 16, 2016 Posted December 16, 2016 They have td04s here was wondering if I could run it without management for a bit you can 7 psi Quote
Sobshotta Posted December 16, 2016 Author Posted December 16, 2016 (edited) http://www.toyotagtturbo.com/forums/showthread.php?76641-A-comprehensive-list-of-parts-required-for-a-TD04-conversion. Have a look at this mate ^^^Niceness I guess I'll give speedvision a go if it sucks I'll go to tdo4 was looking for a blitz or tongs but those are hard to find Edited December 16, 2016 by Sobshotta Quote
gorganl2000 Posted December 19, 2016 Posted December 19, 2016 http://www.speedvisioncps.com/index.php?main_page=product_info&cPath=30&products_id=80&zenid=945dabc9cb34329e58a922528dedba8a if going with speedvision, it may be best to buy directly from sam its possible to get a subaru td04l in Barbados, but i'm not sure how easy it would be to grab a tf035 with our gas quality and other factors in mind, i'd strongly suggest you get at minimum a piggyback which tunes fuel and ignitionnow if you plan to stick to low boost set up, maybe better you stick with the stock ct9 or hybrid ct9 as it will be lower cost to you overall if you already have the other supporting mods. are you running an upgraded exhaust manifold and downpipe?---the stock manifold is not good when you plan to up the power,,,,your engine/pistons may pay the ultimate price Quote
Sobshotta Posted December 21, 2016 Author Posted December 21, 2016 http://www.speedvisioncps.com/index.php?main_page=product_info&cPath=30&products_id=80&zenid=945dabc9cb34329e58a922528dedba8a if going with speedvision, it may be best to buy directly from sam its possible to get a subaru td04l in Barbados, but i'm not sure how easy it would be to grab a tf035 with our gas quality and other factors in mind, i'd strongly suggest you get at minimum a piggyback which tunes fuel and ignitionnow if you plan to stick to low boost set up, maybe better you stick with the stock ct9 or hybrid ct9 as it will be lower cost to you overall if you already have the other supporting mods. are you running an upgraded exhaust manifold and downpipe?---the stock manifold is not good when you plan to up the power,,,,your engine/pistons may pay the ultimate priceI got a tdo4 mani and downpipe at a steal just got to get an external wastegate and I'm good to go Quote
gorganl2000 Posted December 21, 2016 Posted December 21, 2016 is this a decent flowing manifold and d/pipe? do you have the other supporting stuff?--water lines and fittings, oil return pipe, oil line and banjo bolt, preferably fmic, etc. i still advice you to get something to adjust fueling and ignition, especially if you plan to run any sort of decent boost Quote
Sobshotta Posted December 22, 2016 Author Posted December 22, 2016 is this a decent flowing manifold and d/pipe? do you have the other supporting stuff?--water lines and fittings, oil return pipe, oil line and banjo bolt, preferably fmic, etc. i still advice you to get something to adjust fueling and ignition, especially if you plan to run any sort of decent boost I have most of the stuff my mechanic said I just need a external waste gate and management the other stuff are already there Quote
