grantb93 Posted January 8, 2017 Posted January 8, 2017 as aboveI'm not very clued up with brakes :/ i am looking to upgrade my brakes on my glanza but I'm restricted with room behind my alloys as they are 16inch,if anyone could help me source soon better brakes would be grateful thanks Quote
morgey Posted January 8, 2017 Posted January 8, 2017 Ae111 Levin twinpot calipers. St202 celica carriers gt (3sge engine)Astra 1.7tdci 277mm discs You will need a spigot ring machined up to fit the discs to the hubs but other than that its bolt on 277mm upgrade with a thicker disc as well Quote
gorganl2000 Posted January 9, 2017 Posted January 9, 2017 (edited) Ae111 Levin twinpot calipers.St202 celica carriers gt (3sge engine)Astra 1.7tdci 277mm discsYou will need a spigot ring machined up to fit the discs to the hubs but other than that its bolt on 277mm upgrade with a thicker disc as well as morgey said you can contact memeber "russ78" on here, he does have some of these kits sometimes at decent prices Edited January 9, 2017 by gorganl2000 Quote
russ78 Posted January 11, 2017 Posted January 11, 2017 Drop me a pm Buddy I may be able to help Quote
*Pete* Posted January 15, 2017 Posted January 15, 2017 I did a twin pot conversion on my Starlet look at my build thread details are in there! I used Celica ST202 carriers and calipers and used a Corsa C SRI 260mm disc. Quote
5e colin Posted January 15, 2017 Posted January 15, 2017 I did a twin pot conversion on my Starlet look at my build thread details are in there! I used Celica ST202 carriers and calipers and used a Corsa C SRI 260mm disc. are you running spacers ???? Quote
*Pete* Posted January 21, 2017 Posted January 21, 2017 are you running spacers ????I have to run 5mm for my purple cms wheels but my three spokes i got some 13mm I have put longer studs in hubs Quote
5e colin Posted January 21, 2017 Posted January 21, 2017 ha ya thats just for the wheels not for the disc alignment ?? ( between disc and wheel ) so no spacer between disc and hub Quote
*Pete* Posted January 22, 2017 Posted January 22, 2017 ha ya thats just for the wheels not for the disc alignment ?? ( between disc and wheel ) so no spacer between disc and hub nope just had to make ring for diameter of the hubs for the 55mm of the starlet and 60mm of the disc Quote
