Walker96 Posted January 26, 2017 Posted January 26, 2017 Fitted a jam ecu today, everything fine on it apart from the revs will drop to 1k the n back up again didnt do it with my stock ecu. Cheers Quote
T-dog Posted January 26, 2017 Posted January 26, 2017 Just give it a good run , should clear it self through Quote
Walker96 Posted January 26, 2017 Author Posted January 26, 2017 Just give it a good run , should clear it self through Already have mate someone told me to unplug the battery for 20 mins then let it idle for 15 mins hopefully that sorts it Quote
Gainzy Posted January 26, 2017 Posted January 26, 2017 Are you running stock fuel pressure reg? Quote
Walker96 Posted January 26, 2017 Author Posted January 26, 2017 Are you running stock fuel pressure reg? More than likely mate Quote
