matthewmaw Posted February 22, 2017 Posted February 22, 2017 Folks I've got a set of aftermarket 52mm electrical gauges ready to go in and I'm just starting to look into the best way to fit everything. Should be ok wiring the gauges in on the most part but the big question is where/how to mount the oil pressure sender unit? I've yet to find a difinitve solution that isn't essentially a bodge. Can anyone with a similar set up post some pics of how they've done it with a brief explanation? Cheers all - Matt Quote
lukEp Posted February 22, 2017 Posted February 22, 2017 Most people use a sandwich plate on the oil filter housing. Look at this on eBay http://www.ebay.co.uk/itm/222242251921 Quote
akyakapotter Posted February 22, 2017 Posted February 22, 2017 Mine is like that appart from the brass going into the block I have a braided line into the block then to the adapter.Cheers nick. Quote
matthewmaw Posted February 23, 2017 Author Posted February 23, 2017 Mine is like that appart from the brass going into the block I have a braided line into the block then to the adapter.Cheers nick.That's great thanks for that. So the braided line is essentially just an extension line to get the sender away from the block? Quote
akyakapotter Posted February 23, 2017 Posted February 23, 2017 The way it is in the pic has a habbit of snapping off in the block so the extension stops that mine sits up ontop of the gearbox now works perfect. cheers nick. Quote
