wakeabby14 Posted March 21, 2017 Posted March 21, 2017 (edited) So in the last 5-6 days my glanza has lost 3.5L of oil i have never seen anything like it, Its horrendous to say the least. It is dripping from the bottom of the pully to the left of the oil filter, my tyres,wheel arches, drive shafts, chassis is caked in oil. after sitting for just 5 mins after turning the engine off there is a pool about the size of a small serving plate. It will be going in the garage next tuesday for it to be sorted. From doing research it seems like it could be the crank seal/oil pump seal/oil pump/ possibly even the sump seal (doubt it though) So far i have ordered... New crank sealNew Oil pumpNew oil pump sealCam belt with pullys and water pump Not a cheap fix i will tell you that cam belt needed doing anyway so i thought i would do that also. Can any of you guys/gals think of anything at all left i need just in case it could be something else? (oil filter is dry was fresh less than 100 miles ago when i did a full oil change -.- ....) Thanks joshWhat a nightmare!!! Edited March 22, 2017 by wakeabby14 Quote
wakeabby14 Posted March 21, 2017 Author Posted March 21, 2017 Wrong sized oil filter? Its not leaking from the oil filter its compleatly dry noting dripping from it Quote
gorganl2000 Posted March 22, 2017 Posted March 22, 2017 get a cam seal as well....basically the same as the crank seal Quote
wakeabby14 Posted March 22, 2017 Author Posted March 22, 2017 get a cam seal as well....basically the same as the crank seal Will do thanks Quote
sosolid Posted March 26, 2017 Posted March 26, 2017 I have done camshaft seals and crank seals. leaks less but still drip from where yours is. I think its the oil pump seal so ill change that and pump same time. keep us updated Quote
