Sparkythestarlet Posted March 29, 2017 Posted March 29, 2017 Hi guys i know some of you guys have done itb's conversion on your starlets before and they look really good can someone please inform me on whats involved in doing the conversion i.e. parts how to do it where to gets parts from etc thanks Ben Quote
maddox710 Posted March 29, 2017 Posted March 29, 2017 Hi guys i know some of you guys have done itb's conversion on your starlets before and they look really good can someone please inform me on whats involved in doing the conversion i.e. parts how to do it where to gets parts from etc thanks BenA spare corolla inlet mani, set of 600cc motorbike throttle bodies, 4x silicone couplers.and basically everything else is custom and up to you how you do it. Remember throttle cable needs mounting somehow and you need to get some vacuum ports tapped into the inlet.Honestly can't see why more people don't do it. Tbh though there's not a lot more power to be had and they can be tricky to get running right on a diy setup Quote
Calum122 Posted March 30, 2017 Posted March 30, 2017 A spare corolla inlet mani, set of 600cc motorbike throttle bodies, 4x silicone couplers.and basically everything else is custom and up to you how you do it. Remember throttle cable needs mounting somehow and you need to get some vacuum ports tapped into the inlet.Honestly can't see why more people don't do it. Tbh though there's not a lot more power to be had and they can be tricky to get running right on a diy setupEasier to turbo these engines, and more performance. I really don't know why people want to gush over ITB when the power is minimal and the sound is nothing compared to spool. Each to their own, but for the money I'd stick with a low PSI CT9 on an N/A over ITB. Although given Sparky's history of posts I expect he is more testing the water rather than venturing down this route. Quote
Sparkythestarlet Posted March 30, 2017 Author Posted March 30, 2017 Yeah just testing the water as unsure on what route to take got the love for the starlet back so wanna do some stuff i am more incline to turbo it on low boost as is apparently quite easy to do Quote
Stu Posted April 1, 2017 Posted April 1, 2017 To get the most out of them you really need to run an aftermarket ecu and tune in alphaN (TPS mode). By playing with different intake lengths ie distance from back of valve to butterfly to end of trumpet you can shift the power band around abit. Much trickier science thats for sure. Helmholtz intake resonance is a good topic to read up on Quote
