Daniel blue starlet Posted April 10, 2017 Share Posted April 10, 2017 I have a 4efe in a crashed starlet(ep91) and i want to pit it into my ep80, will it be straight forward in just popping the engine in and then using the 4efe engine loom or will i have to change anything like wiring etc ? Quote Link to post Share on other sites
PaddyDoyle Posted April 10, 2017 Share Posted April 10, 2017 Richard clarke does conversion looms. Use the 12 valve charging and starting wiring and use his loom for engine management just needs earth and ignition live.Carb shells dont come with a return line and 12 valve lines slightly smaller bore. Will need to change fuel lines either from a ep82 or run your own.Needs a fuel pump fitted and wired up to ignition.Ep82 tank also a good idea as carb tanks are not baffled and pump can draw air.Thermostat housings will need some sensors mixed and matched for fan switch, dash water temp and water temp for ecu.If youre using a ep90 4e you'll need engine mounts swapped over from the ep80 12 valve.Exhaust will need modified, downpipe shortened and 4e flange welded on. Think thats everything. Handy enough if you have a donor car. Quote Link to post Share on other sites
Daniel blue starlet Posted April 11, 2017 Author Share Posted April 11, 2017 Thanks paddy,Sounds like a good bit to do but have all the parts from a scrap ep82 anyway so shouldn't be too hard,how much do Richards looms cost?thanks !! Quote Link to post Share on other sites
mccartney11 Posted April 11, 2017 Share Posted April 11, 2017 I'm using one of Richards looms in my ep70, works a treat:) Quote Link to post Share on other sites
Starlet__SR Posted June 4, 2017 Share Posted June 4, 2017 Are these looms still available? Quote Link to post Share on other sites
mccartney11 Posted June 4, 2017 Share Posted June 4, 2017 Yes get onto Richard Clarke on facebook Quote Link to post Share on other sites
Starlet__SR Posted June 4, 2017 Share Posted June 4, 2017 Cheers matey, think i've got the right guy lol. Quote Link to post Share on other sites
antheon2010 Posted December 20, 2018 Share Posted December 20, 2018 Can anyone tell me who is this guy please Quote Link to post Share on other sites
