CT9 Hybrid turbo my ct9 is dead :'(
How bad are the cracks? Most ct9's I've seen have been cracked around the wastegate.
Mine ran fine cracked
Its really really bad, like crack all the way down to the turbine side and all the way down the wastegate side and the cracks are like 1MM wide and you can stick your fingernail in it and there is room to move it around.
