glanza ep91 23 Posted June 4, 2017 Posted June 4, 2017 (edited) Im fitting my twinpot carries and the disk is rubbing on the carrier and on the otherside it fits perfect?? Edited June 4, 2017 by glanza ep91 23 Quote
glanza ep91 23 Posted June 4, 2017 Author Posted June 4, 2017 Ya evething is tighen down i thinking could it be a fucked bearing car been off the road for a while Quote
SpikeyJp_68 Posted June 4, 2017 Posted June 4, 2017 Ya evething is tighen down i thinking could it be a fucked bearing car been off the road for a whileDid you sand down the stub axle before putting the disk on ? Quote
glanza ep91 23 Posted June 4, 2017 Author Posted June 4, 2017 Yup the disk is on flat it the bearing i think because there abit of play in it and i think the wobbel is causing it to rub Quote
glanza ep91 23 Posted June 6, 2017 Author Posted June 6, 2017 The disk and carries are fine because it fit the otherside perfect it just that one side where it rubs hence y i think it could be the bearing Quote
epcashin Posted June 6, 2017 Posted June 6, 2017 10mm spacer behind the discs would work would have to get a machine shop to make up soemthing Quote
gorganl2000 Posted June 6, 2017 Posted June 6, 2017 (edited) The disk and carries are fine because it fit the otherside perfect it just that one side where it rubs hence y i think it could be the beari based on this, i think something is amiss with the side that is rubbing as well,,,check out the problem side carefully---any hub changes? if it was the set up, most likely both sides would have an issue Edited June 6, 2017 by gorganl2000 Quote
ChineseMafia Posted July 6, 2017 Posted July 6, 2017 Im fitting my twinpot carries and the disk is rubbing on the carrier and on the otherside it fits perfect?? Quote
