dwd Posted June 5, 2017 Posted June 5, 2017 Im having a problem selecting reverse. It grinds a lot. I have just changed the gearbox, including the fork and release bearing. The clutch seemed in good condition when I had the box out. It’s a lot worse now with the new gearbox. It can barely get it into reverse. The forward gears are all fine. Has anyone any ideas what the problem could be? Can the clutch pedal be adjusted? by the way, its an n/a EP82 Quote
dwd Posted June 8, 2017 Author Posted June 8, 2017 Ok I have found the problem. And yes I am an idiot lol. This bolt was left out of the box. I cant get it in now because whatever it screws into inside the gearbox doesn’t line up. Does anyone know how I can get it fitted with the box in the car? Any help would be greatly appreciated. Quote
Zak.p Posted July 20, 2017 Posted July 20, 2017 Have the same problem, grinding everytime I select reverse all other gears are ok, have you sorted yours now? Quote
Zak.p Posted July 20, 2017 Posted July 20, 2017 Is this going into reverse from neutral?Yeah mate happens almost every time sounds horrible lol Quote
