ashbuxton Posted June 17, 2017 Posted June 17, 2017 Had a mechanic friend fit my LSD box but he's just rang me with a problem. He's saying When you attach the cables to the box its dragging the gear stick over to one side so you cant select any gears.Anyone any ideas why this could be happening?Thanks in advanceAshley Quote
5e colin Posted June 17, 2017 Posted June 17, 2017 (edited) Non lsd turbo bracket bolted to the LSD box as there different !! ???? Edited June 17, 2017 by 5e colin Quote
ashbuxton Posted June 17, 2017 Author Posted June 17, 2017 Sorry to act dumb colin and appreciate the help can you elaborate on what you mean by lsd turbo bracket or have a pic or anything?Thanks for the reply Quote
ashbuxton Posted June 17, 2017 Author Posted June 17, 2017 Sorted he'd put the cable bracket on wrong way around. Thanks Quote
5e colin Posted June 17, 2017 Posted June 17, 2017 (edited) The gearbox cable selector bracket that's bolted to the box to hold cables in place where the selector cable's are held in place with the U clipsWasn't far off haha Edited June 17, 2017 by 5e colin Quote
ashbuxton Posted June 17, 2017 Author Posted June 17, 2017 Yer pretty close mate. Thanks again for the quick response. This box still crunching going into 2nd same as the last box. I assumed it was the box that was causing the crunching could it possibly anything else? It feel crunchy higher up like just below the stick? Any ideas? Quote
goldenvtr Posted June 17, 2017 Posted June 17, 2017 could try adjusting the pedal (under the steering column) incase its not fully disengaging the clutch Quote
ashbuxton Posted June 18, 2017 Author Posted June 18, 2017 could try adjusting the pedal (under the steering column) incase its not fully disengaging the clutchWould that issue not cause all gears to not engage properly and not just 1st to 2nd? Quote
5e colin Posted June 18, 2017 Posted June 18, 2017 yup too loose is grind and to tight is clutch slip try sugar cube also on the box ( located in the selector arm twist the cube 90degree its probly another crunchy syncro ( probly ) Quote
ashbuxton Posted June 19, 2017 Author Posted June 19, 2017 I've owned 3 starlets and 4 gearboxes and every single one has had a 2nd gear crunch. Is it just me or does everyone's starlets crunch in 2nd? Quote
ashbuxton Posted June 19, 2017 Author Posted June 19, 2017 😩 tried sugarcube tonight aswell as new oil and still crunching safe to say synchros on their way out! Never mind rebuild when engine out for forging next year if gearbox survives that long! Quote
5e colin Posted June 19, 2017 Posted June 19, 2017 Some boxes crunch for years double clutch helps an low rpm to Quote
Calum122 Posted June 20, 2017 Posted June 20, 2017 Put your name down for the Carbon Syncro Kits that Tegiwa are trying to get MFactory to put into production Quote
ashbuxton Posted June 20, 2017 Author Posted June 20, 2017 Good idea any idea how much they gonna cost? Quote
shaq Posted October 3, 2017 Posted October 3, 2017 (edited) Lube gbox cables try and get maybe slightly longer cables bent bracket where the gbox cable is attached with the metal plate slot or bent plate worn bush.the plate can be pulled with pliers or a tong.that's a nice line for the females I need your tongs my gearstick is crunchy or my gears are grindy.hey tongs my 2nd gear is not engadging Edited October 3, 2017 by shaq Quote
