Had a mechanic friend fit my LSD box but he's just rang me with a problem. He's saying When you attach the cables to the box its dragging the gear stick over to one side so you cant select any gears.
Anyone any ideas why this could be happening?
Thanks in advance
Ashley
Sorry to act dumb colin and appreciate the help can you elaborate on what you mean by lsd turbo bracket or have a pic or anything?
Thanks for the reply
The gearbox cable selector bracket that's bolted to the box to hold cables in place where the selector cable's are held in place with the U clips
Wasn't far off haha
Edited by 5e colin
Yer pretty close mate. Thanks again for the quick response. This box still crunching going into 2nd same as the last box. I assumed it was the box that was causing the crunching could it possibly anything else? It feel crunchy higher up like just below the stick? Any ideas?
  On 6/17/2017 at 10:29 PM, goldenvtr said:
could try adjusting the pedal (under the steering column) incase its not fully disengaging the clutch
Would that issue not cause all gears to not engage properly and not just 1st to 2nd?
I've owned 3 starlets and 4 gearboxes and every single one has had a 2nd gear crunch. Is it just me or does everyone's starlets crunch in 2nd?
😩 tried sugarcube tonight aswell as new oil and still crunching safe to say synchros on their way out! Never mind rebuild when engine out for forging next year if gearbox survives that long!
  • 3 months later...
Lube gbox cables try and get maybe slightly longer cables bent bracket where the gbox cable is attached with the metal plate slot or bent plate worn bush.the plate can be pulled with pliers or a tong.that's a nice line for the females I need your tongs my gearstick is crunchy or my gears are grindy.hey tongs my 2nd gear is not engadging
Edited by shaq
