lukEp Posted June 21, 2017 Share Posted June 21, 2017 (edited) As title. I'm after a HKS PFC F-con ECU pref for a EP91 but EP82 concidered. I want the full kit that includes the MAP sensor and Fuel cut defender please. PM me. Edited June 21, 2017 by lukEp Link to post Share on other sites
5e colin Posted June 21, 2017 Share Posted June 21, 2017 Don't forget a GCC its vital or old 5 button safc. Twist nobs Don't forget a GCC its vital or old 5 button safc. Twist nobs Link to post Share on other sites
turbominicooper Posted June 21, 2017 Share Posted June 21, 2017 I've got the fcon with harness and fcd but no map... however the chip inside doesn't require the map sensor Link to post Share on other sites
parker85 Posted June 21, 2017 Share Posted June 21, 2017 How much mate and is it for glanza or ep82 Link to post Share on other sites
lukEp Posted June 21, 2017 Author Share Posted June 21, 2017 I've got the fcon with harness and fcd but no map... however the chip inside doesn't require the map sensor Link to post Share on other sites
5e colin Posted June 21, 2017 Share Posted June 21, 2017 Luke if the chip inside is E304 then map if it says anything els on it *#### it requires no map but limited then to stock map sensor Link to post Share on other sites
lukEp Posted June 21, 2017 Author Share Posted June 21, 2017 Cheers colin Link to post Share on other sites
Foggy Posted June 21, 2017 Share Posted June 21, 2017 (edited) I have the one that doesn't require a map sensor. Just uses a fcd Edited June 21, 2017 by Foggy Link to post Share on other sites
chrishucker Posted June 22, 2017 Share Posted June 22, 2017 I've got a his f-con sz if your interested? Link to post Share on other sites
Zoib_786 Posted June 22, 2017 Share Posted June 22, 2017 I have everything here but a map sensor going cheap at £150 Ecu Fcd Gcc Link to post Share on other sites
