Sam_23 Posted June 30, 2017 Share Posted June 30, 2017 (edited) i have recently fitted a brand new AEM afr gauge to my glanza and when i start it up from cold its reading 10.3 afr when it warms up it reads 11.3 thats on idle when im driving it off boost just cruising its reading 14.3-14.8 on boost foot down its reading in the 10's and when i let off its running off the gauge lean its just had newplugsleadsdizzy caprotor arm also it is running .75-.8 bar with the adjustable hks actuator Edited June 30, 2017 by Sam_23 Quote Link to post Share on other sites
gorganl2000 Posted June 30, 2017 Share Posted June 30, 2017 what ecu is in the car?.....any diagnostic codes? maybe someone with a stock ecu and wideband afr fitted can confirm what you are seeing Quote Link to post Share on other sites
5e colin Posted June 30, 2017 Share Posted June 30, 2017 (edited) Ecu temp sensor or map sensor is the usual culprit as the will give false signals over feuling Temp sensor stuck in cold modeOr map seeing false boostDoes the aem need calibration ? Edited June 30, 2017 by 5e colin Quote Link to post Share on other sites
Sam_23 Posted June 30, 2017 Author Share Posted June 30, 2017 its the factory ecu and nah no codes the only code on it is the speed sensor because its not working the aem doesn't need calibration been done from factory so i have been told i shall see if i can get some spare ones and try them or something Quote Link to post Share on other sites
goldenvtr Posted July 1, 2017 Share Posted July 1, 2017 stock fuel pressure and injectors? concidering there only a few quid each id change water temp and air temp sensors, and run a newh vacuum line from the inlet manifold to the map sensor, prob cost 50p in hose lol Quote Link to post Share on other sites
Timmah Posted July 7, 2017 Share Posted July 7, 2017 On 7/1/2017 at 7:00 PM, goldenvtr said: stock fuel pressure and injectors? concidering there only a few quid each id change water temp and air temp sensors, and run a newh vacuum line from the inlet manifold to the map sensor, prob cost 50p in hose lol Quote Link to post Share on other sites
goldenvtr Posted July 7, 2017 Share Posted July 7, 2017 On 7/7/2017 at 2:58 AM, Timmah said: Don't suppose you know of a web store that sell the air temp sensor? ID Workz and Tuning Developments have the Water Temp sensor, but not the air temp one. just had a quick look on google and cant find one i know camskill uk used to sell them. im using a cosworth iat on my stock ecu (but zisco inlet) but ill be refitting my standalone shortly. i dont know how much its affected this but it drives on http://www.ebay.co.uk/itm/Ford-Cosworth-YB-ACT-Air-Temp-Sensor-Temperature-/152588156869?epid=1538384972&hash=item2386f67fc5:g:pC0AAOSwwvZZQ9US uses a standard bosche plug (about 4£) however i dont recomend this unless you have suitable mapping Quote Link to post Share on other sites
federalman Posted October 23, 2017 Share Posted October 23, 2017 The AEM wideband to as far as I know (I've run mine for about 6 years so the instructions went long ago) doesn't need calibrating. Mine since day one has given no reading when you let off and it does exactly the same in my Silvia. Seems to be running a bit rich with those numbers, though to be honest I've run a rising rate fuel pressure regulator for about the same amount of time as the TD04 and AEM wideband and get similar numbers on boost with no problems, plugs look fine every time I change them and the bores are fine. Personally with stock regulator and injectors I'd do as others have suggested and try changing sensors as others have suggested. Quote Link to post Share on other sites
