Nilz90 Posted July 12, 2017 Posted July 12, 2017 Hi,I was wondering whats the best one for the Starlet GT or is it better to have a recirculating one? I brought the car with none.Also i have a front mount intercooler will i need to cut the pipe?Thanks Quote
Patches Posted July 13, 2017 Posted July 13, 2017 You should check out this video, it should explain a lot of questions you might have about dump valves. >https://www.youtube.com/watch?v=Z_fG_b65WiU I wouldn't say there is a "best" dump valve, just pick one you like the sound of. Would probably avoid fake ones and baileys tho as they seem pretty unreliable Quote
Nilz90 Posted July 13, 2017 Author Posted July 13, 2017 Cheers mate very useful video.I'm looking at one I like currently. Would the hks ssqv4 with a 34mm flange fit the starlet? It's a universal one. Quote
Patches Posted July 13, 2017 Posted July 13, 2017 Cheers mate very useful video.I'm looking at one I like currently. Would the hks ssqv4 with a 34mm flange fit the starlet? It's a universal one. The standard outlet size is 25mm on the starlet and is connected by hose so you'll probably need a flange adaptor and maybe a reducer hose. Have a look at the pictures of the HKS fitted to other starlets to get an idea of what you might need Quote
Nilz90 Posted July 13, 2017 Author Posted July 13, 2017 I had a look on google and I saw that most starlets have the intercooler pipe cut and the dump valve fitted on there. Couldn't seem to see one with the hks and a front mount intercooler. Does anyone have a pic of one? Also do you know if this is the only option as I would prefer not to cut the intercooler pipe? Quote
Patches Posted July 14, 2017 Posted July 14, 2017 I had a look on google and I saw that most starlets have the intercooler pipe cut and the dump valve fitted on there. Couldn't seem to see one with the hks and a front mount intercooler. Does anyone have a pic of one? Also do you know if this is the only option as I would prefer not to cut the intercooler pipe? Put up a picture of what you have at the moment so I can get a better idea of what you need Quote
Nilz90 Posted July 14, 2017 Author Posted July 14, 2017 Here's a pic of the engine bay it has a td04 set up.http://i892.photobucket.com/albums/ac122/n1lz/IMG_3855_1.jpg Quote
Patches Posted July 14, 2017 Posted July 14, 2017 Here's a pic of the engine bay it has a td04 set up.http://i892.photobucket.com/albums/ac122/n1lz/IMG_3855_1.jpg Sorry dude I can't see that image, photobucket changed their settings so you can't share images without paying now Quote
Calum122 Posted July 14, 2017 Posted July 14, 2017 (edited) Just get the one they use on WRC rally cars... Edited July 14, 2017 by Calum122 Quote
Nilz90 Posted July 14, 2017 Author Posted July 14, 2017 Sorry mate didn't realise. Try the below linkhttps://ibb.co/nDjT7v Quote
Patches Posted July 14, 2017 Posted July 14, 2017 No worries, it just happened recently. OK so you have a couple of options, you could buy a weldable flange and weld it onto the intercooler piping. http://www.ebay.co.uk/itm/Alloy-Weld-On-Pipe-Adapter-Flange-To-Fit-HKS-Sqv-Ssqv-Blow-Off-Dump-Valve-/361258426571?hash=item541cae20cb:g:3ioAAOSwpDdVG-D7 make sure its the same type of metal as your piping. Dean at RW Developments or a decent local fabricator should be able to sort this out for you Or you could cut a section of the intercooler piping you have out and replace it with something like this, 4 clamps and some silicone hose http://www.ebay.co.uk/itm/Alloy-T-Piece-2-51mm-I-D-50mm-Tial-Dump-Blow-Off-Valve-BOV-Flange-V-Band-Pipe-/191943594494?hash=item2cb0bad1fe:g:ITcAAOSwBahU2KtU Quote
Nilz90 Posted July 14, 2017 Author Posted July 14, 2017 Thanks mate this is really helpful much appreciated. I think I'll go for the first option would be much tidier. Quote
DRiiFTiE Posted July 14, 2017 Posted July 14, 2017 Run without a DV, all about the chaaaaaater sutttuuuuuu Quote
Andrew Miller Posted July 18, 2017 Posted July 18, 2017 I have an hks ssqv for sale with the hose to attach it to a pipe on the intercooler if you need it. Quote
