Hello, I wa fitting my alarm today and all went well apart from the hazards/indicators. My alarm box gives out a 12v pulse when locked and 2x 12v pulses when unlocked so that's ok. I probed green and black wire out of indicator switch and it was getting an indicator pulse so wired it up and nothing. Pulled out hazard switch and found green and black wire giving same pulse but when wired up still no indicators when fob is pressed. I even probed green/black wire and green yellow wire at o/s kick panel again getting indicator pulse but when wired up nothing! Any hints to what I'm missing? Cheers in advance
Use the wires out the back of the hazard switch thats were mine are. Make sure you connect to output not input.
Edited by lukEp
I tried under there and also looked at back if hazard switch. I'm definitely doing something wrong I will have another go on Monday. Thanks for the replys people.
