turbominicooper Posted July 26, 2017 Posted July 26, 2017 Yo yo, Need some help finishing off my project and think it could be wiring related. So converted a 2ee na to 4efte using the original loom but converted for coil pack and clip on dizzy /leads. The car starts and drives fine when it's cold however when it warms up it starts running rich and black smoke comes out back on idle. Spoke to colin briefly who said it could be temp sensor of which I checked and hooked up. When I was looking the 2ee loom had 2 pins the one to ecu and one I think is live as when I bridged it first it would blow fuses?? The 4efte sensor is single wire so I'm not sure what this one is for? I did think it may of been the lamda and also air intake THA sensor as they were the only faults registered on the diagnostics. Think I've sorted the lamda issue out now and the THA fault (24) won't stop the engine running right from past experience. Also if I switch the car off once it's warmed up it won't start again until the next day. I'm currently flushing the faults by leaving the ecu disconnected but all in all the wiring looks ok just what's people's thoughts? I had this engine running prior to install so know everything is ok with it. Last thing when i look at the timing when it's hot and bridged for diag mode it seems the timing is jumping around a bit. Any ideas guys? Sent from my SM-G900F using Tapatalk Quote
5e colin Posted July 26, 2017 Posted July 26, 2017 the engine would run normal ish ofboost without the air intake sensor i ran so for a while disconnected because sensor was broken ecu temp sensor i would be looking at as if that's dodgy its a cunt to run timin jumping could be custom wiring issue you have done or dodgy dizzy Quote
turbominicooper Posted July 27, 2017 Author Posted July 27, 2017 What's best way to test the temp sensor, what racing should I be looking for?Also using one then chinese alloy crank pulley so dyu think that could b messing timing up? Quote
5e colin Posted July 27, 2017 Posted July 27, 2017 Could be pulley but there solid so don't think the jumping is from thatGet a timing disk and find your true tdc and mark it or check Put wires on the terminals for sensor connected to multimeter and trow in ketel that's how I test I'm sure some of the lads will know the spec of the sensor so they might reply Quote
turbominicooper Posted July 27, 2017 Author Posted July 27, 2017 Yuh cool will do them tests but now I'm at a total loss where I've lost all spark and can't get the focker started now. Went over all wires, ecu, timing, dizzy so thinking something custom has come loose. Will let you know once I've got it sorted. ..again Quote
turbominicooper Posted August 4, 2017 Author Posted August 4, 2017 Right car is sorted and running again however still rich.I've tested the sensor and it reads2.29 off car1.85 body temp0.20 in a boiling pan.Does anyone know what the range should be?I think the sensor looks ok so is it possible there's a broken wire somewhere to the ecu, would I be safe to make a slit to get a reading the ecu end?Sent from my SM-G900F using Tapatalk Quote
turbominicooper Posted August 5, 2017 Author Posted August 5, 2017 Managed to find the range and the sensor is working 100% even traced all the wires to and from the ecu.Really stuck here guys car is running rich and can't drive it at all.Have looked at:EcuEct sensor PlugsWiringAll that's left to workout is if it could b related to some rogue wiring left over from 2ee setup?? http://www.ukstarletowners.com/topic/106810-sensors-on-water-housing/#entry1219562Sent from my SM-G900F using Tapatalk Quote
5e colin Posted August 5, 2017 Posted August 5, 2017 That's a funny 1 as ecu temp and map are the only 2 that alter feuling is your AIT sensor OK try disconnecting an check see if its different you will have to start fishing to get to the bottom of it also tps check Quote
turbominicooper Posted August 5, 2017 Author Posted August 5, 2017 Yuh I'm literally testing each sensor but I know they should b ok as they all ran prior to installment.Just checkling map over now. Gives me:5v input4.5v signal disconnectedGood groundThen 2.6v signal connected.Go's up to 4v with pressure injectedOnly diff is starting voltage between my 2 maps I'm trying with.Will look at ait next... Quote
turbominicooper Posted August 5, 2017 Author Posted August 5, 2017 Ait seems ok was giving a reading but the connector was faulty so have swapped a newer one on to it. Now there are 0 faults when I bride diagnostics port.... however it does repeatedly flash?? Quote
turbominicooper Posted August 6, 2017 Author Posted August 6, 2017 What dyu reckon colin do it the crude way with some management to lean it out? Quote
turbominicooper Posted August 6, 2017 Author Posted August 6, 2017 Think I'll get this on the go and see what exactly is going on https://youtu.be/YfbG_h_PlrE Quote
5e colin Posted August 6, 2017 Posted August 6, 2017 No not crude way it will give issues in the future when tuning Quote
turbominicooper Posted August 6, 2017 Author Posted August 6, 2017 Yeh that was my thinking to. Will do data logger and see what's going on Quote
turbominicooper Posted August 7, 2017 Author Posted August 7, 2017 Ok so had another look today with the zf logger running and noticed that the ecu believes the engine is running full lean .So when I looked closer saw (and remembered) that the 2e engine ran a 2 wire lamda as opposed to a gt's single.So question is what to do with the brown one?Do I bridge it to an earth and run the single wire lamda it swap in a 2 wire lambda?Sent from my SM-G900F using Tapatalk Quote
TrisK Posted August 8, 2017 Posted August 8, 2017 I've got an ep80 manual at home. I'll look at the wiring when I'm home from work Quote
turbominicooper Posted August 8, 2017 Author Posted August 8, 2017 I've got an ep80 manual at home. I'll look at the wiring when I'm home from work Quote
5e colin Posted August 8, 2017 Posted August 8, 2017 Just test by running single wire to ecu that's what I would do Quote
turbominicooper Posted August 8, 2017 Author Posted August 8, 2017 All sorted boys. Was the lamda sensor that was causing the issue (odd cause that lamda worked fine in my gt). Anyway swapped it out for a 4 wire one and used the existing cabling for the signal and ground then even wired up a harness for the heater and now all is running as expected thank fook.Thanks to TrisK for the wiring diagrams and as always colin for input knowledge and guidance Sent from my SM-G900F using Tapatalk Quote
5e colin Posted August 8, 2017 Posted August 8, 2017 man i need those books where do i get em lads ???? Quote
turbominicooper Posted August 8, 2017 Author Posted August 8, 2017 TrisK has a mountains worth apparently Quote
TrisK Posted August 8, 2017 Posted August 8, 2017 It's something I need to get round to scanning inSo much useful knowledge in there Quote
turbominicooper Posted August 9, 2017 Author Posted August 9, 2017 Send them over to me dude and ill get them scanned in then send them back. Wouldn't take long Quote
