typh183 Posted August 14, 2017 Posted August 14, 2017 i was going to order a set of wishbones from id workz earlier and i thought i would just call to make sure they would fit my 94 ep82, they said they only have the glanza wishbones which dont fit an ep82. Everything i have read on the internet says that the wishbones are the same for late ep82's and glanzas...is this correct? Quote
5e colin Posted August 14, 2017 Posted August 14, 2017 P8 and p9 are interchangeable wishbone's Quote
typh183 Posted August 14, 2017 Author Posted August 14, 2017 P8 and p9 are interchangeable wishbone's Quote
Calum122 Posted August 14, 2017 Posted August 14, 2017 No? I think he means P8 P9 I.E. EP80 81 82 fall under P8 and EP91 95 under P9. I.e. WIshbones from across the board are interchangeable. Quote
typh183 Posted August 14, 2017 Author Posted August 14, 2017 No? I think he means P8 P9 I.E. EP80 81 82 fall under P8 and EP91 95 under P9. I.e. WIshbones from across the board are interchangeable. Quote
Ryncewind Posted August 14, 2017 Posted August 14, 2017 okay i understand, so ideally i need to find some specific ep82 wishbones.No. Either will work. Quote
Calum122 Posted August 14, 2017 Posted August 14, 2017 when i spoke with id workz earlier, the chap on the phone was 100% sure that the ep91 wishbones wont work on my ep82 hmmmm Yeah well, My understanding is this. Yes they will fit, but the bushes are different sizes. Quote
5e colin Posted August 14, 2017 Posted August 14, 2017 i have glanza wishbones in my gtturbo ( ep82 ) its on some that the metal bracket is indeed wider and narrower but the wishbones them self fit as ep80/81/82/91 share same floorpan Quote
Idrees Posted August 14, 2017 Posted August 14, 2017 EP91 wishbones will not fit using your EP82 rear mounting bracket as the rear bushes are smaller on the EP91 wishbones. The front bushes are also smaller but these do not affect fitment. If you want to use EP91 wishbones you have two options:1. Source EP91 rear mounting brackets2. Fit an Anti-lift kit (supplied with new bushes and brackets) Quote
maddox710 Posted August 14, 2017 Posted August 14, 2017 Also one of the two is stamped metal and the other is like cast design and weigh a ton Quote
typh183 Posted August 14, 2017 Author Posted August 14, 2017 EP91 wishbones will not fit using your EP82 rear mounting bracket as the rear bushes are smaller on the EP91 wishbones. The front bushes are also smaller but these do not affect fitment. If you want to use EP91 wishbones you have two options:1. Source EP91 rear mounting brackets2. Fit an Anti-lift kit (supplied with new bushes and brackets)Idrees thanks for taking the time to reply, that was the next thing I was going to ask, so if I was to order the new wishbones from you along with a whiteline anti lift kit that would fit my ep82 no problems? Quote
Idrees Posted August 14, 2017 Posted August 14, 2017 Idrees thanks for taking the time to reply, that was the next thing I was going to ask, so if I was to order the new wishbones from you along with a whiteline anti lift kit that would fit my ep82 no problems? Quote
