SKINY Posted September 3, 2017 Posted September 3, 2017 So, just done a refurb on a good 2nd hand tank, outside is like new, stripped to metal, red leaded, stonechip etc.looked inside and it's full of crappy rusty crap, anyone know the best way to clean it ?? Been looking online and see folk say vinegarCheers Quote
Ryncewind Posted September 3, 2017 Posted September 3, 2017 Empty a bag of big nuts into it and shake it around then tip them out and clean them and repeat. That's what i did with my RX7 fuel tank and it was sweet afterwards! Quote
SKINY Posted September 3, 2017 Author Posted September 3, 2017 Raided Asda earlier for 5L worth of the finest cheapo bottles lol, plan is to fire that in combined with some 6MM gravel from work and shake life out of it i can get my arm in a fair bit so will get the scrub brush in too Quote
Ollieh17 Posted September 3, 2017 Posted September 3, 2017 Then you have 6mm gravel stuck in there? At least nuts are easier to get out Quote
Starlet__SR Posted September 3, 2017 Posted September 3, 2017 Nuts and washers. Gravel will just break up and leave dust. Quote
SKINY Posted September 4, 2017 Author Posted September 4, 2017 Fair points, of course it will be thoroughly cleaned out before fitting it Quote
Starlet__SR Posted September 4, 2017 Posted September 4, 2017 Failing that, look into electrolysis Quote
SKINY Posted September 20, 2017 Author Posted September 20, 2017 Just to update this,The vinegar soak worked ok but still needed scrubbing off, I then got some acid that they use to clean the inside of concrete mixers with, real nasty stuff smokes when you open the bottle and the fumes would choke you wild handy, about 200ml put in then half filled the tank with water mixed in, sealed up and shook about well, next day opened it up and where the mix was the tank was like brand new inside, so I then fired a litre in and filled it to the neck while swishing it about, 2 days later tank is like brand new inside Gave it a good rinse out with the hose and then petrol straight after then fitted it Quote
