glanzadude Posted September 10, 2017 Posted September 10, 2017 Lads tried to remove my track rod end but the split pin is rusted and wont come out. any ideas for me please Quote
daniel_g Posted September 10, 2017 Posted September 10, 2017 Bash a socket over it and undo it, it will break.If youre changing the track rod end anyway it wont matter.If you are putting it back on then you need a small punch to push the broken pin through. Quote
glanzadude Posted September 10, 2017 Author Posted September 10, 2017 Bash a socket over it and undo it, it will break.If youre changing the track rod end anyway it wont matter.If you are putting it back on then you need a small punch to push the broken pin through.i am going to re use the track rod end. could i drill it out? Quote
morgey Posted September 10, 2017 Posted September 10, 2017 Yeah drilling it will he fine. A good impact gun is great for breaking them off too Quote
glanzadude Posted September 10, 2017 Author Posted September 10, 2017 I was thinking spraying it with wd40 and leave it for a time and try and use a punch to get it out as i dont want to brake the drill bit in the hole Quote
