snails ep91 Posted September 13, 2017 Share Posted September 13, 2017 can anyone shed some light on this. i have a starlet s which i have done a turbo conversion on. Ive put a glanza set of clocks in but they are the wrong mileage. i have the original N/a cluster which reads the correct mileage. now i have a speedo convertor to show mileage rather than kms on the gearbox but would putting the n/a odometer in it affect the reading at all? Quote Link to post Share on other sites
snails ep91 Posted September 15, 2017 Author Share Posted September 15, 2017 Anyone shed any light? Quote Link to post Share on other sites
morgey Posted September 15, 2017 Share Posted September 15, 2017 If i had to hazard a guess id say it would under read with the UK odometer. Quote Link to post Share on other sites
SKINY Posted October 1, 2017 Share Posted October 1, 2017 You can disassemble the clocks and swap the mileage cog assembly over. Also can set the milage to when it's out Quote Link to post Share on other sites
Whitenoize Posted October 1, 2017 Share Posted October 1, 2017 Can you not just plug a speedo cable into the clocks and put a drill on reverse on the other end of the cable wind them back 😳 Quote Link to post Share on other sites
SKINY Posted October 1, 2017 Share Posted October 1, 2017 Can you not just plug a speedo cable into the clocks and put a drill on reverse on the other end of the cable wind them back Quote Link to post Share on other sites
