JBishop Posted December 7, 2017 Posted December 7, 2017 Hi, my glanza is running a stock 5E bottom end and I’m wanting to stay with the 200mm clutch for quicker revs, is this possible and is there any clutch out there that will hold? And if any one has td04 on a stock 5E with glanza Head, what power have they had out of it ? Quote
lukEp Posted December 7, 2017 Posted December 7, 2017 The 200mm and 212mm flywheel are the same size/weight. It's only the bolt pattern/dowls are in a different position on the flywheel. The only slight weight loss you will get is from the pressure plate and that won't be anywhere near enough weight to notice a difference. Quote
JBishop Posted December 7, 2017 Author Posted December 7, 2017 5 minutes ago, lukEp said: The 200mm and 212mm flywheel are the same size/weight. It's only the bolt pattern/dowls are in a different position on the flywheel. The only slight weight loss you will get is from the pressure plate and that won't be anywhere near enough weight to notice a difference. Just thinking of centre to outer diameter of the clutch pal as the bigger clutch takes more to spin it. If you get me? Quote
daniel_g Posted December 8, 2017 Posted December 8, 2017 Yeah that would be negligible. You notice the difference if you get a flywheel lightened. Quote
