20 hours ago, nikhilkamdar12 said:
Just need an old one for setting my timing on my standalone. As I have COP setup only accurate way.
Threw away my old ones :(
Have you tried using the timing light on the coil wiring? I've heard that sometimes that gives off a good enough signal for a timing light to use.
There are also spark plug extension leads so you can connect a lead between the coil and the spark plug
  • 2 weeks later...
Hi mate,
I have but unfortunately it does not give a true reading when timing up the engine. It does flash, but apparently it has a tendency to drift etc..
So want to get a true reading using an old HT lead to get the timing bang on.
