Nilz90 Posted May 15, 2018 Posted May 15, 2018 Quick question will I be ok on a td04 with a standard exedy clutch? Sorting out the rear end crank seal before I get a remap and already have this clutch new. Will be going emange blue. Quote
adzy Posted May 16, 2018 Posted May 16, 2018 No issues with standard clutch in mine. td04 @ 1bar Quote
Nilz90 Posted May 16, 2018 Author Posted May 16, 2018 How much bhp is yours running? I’m looking to run around 220-230. Spoke to TD and they said with a standard clutch it will only be able to run around 200 or 210 if I’m lucky. Car is currently in the garage for a rear end seal so clutch job out even though I fitted one a couple of months ago. So thinking would I be better of upgrading it this time? Which clutches do people recommend? Quote
adzy Posted May 16, 2018 Posted May 16, 2018 41 minutes ago, Nilz90 said: How much bhp is yours running? I’m looking to run around 220-230. Spoke to TD and they said with a standard clutch it will only be able to run around 200 or 210 if I’m lucky. Car is currently in the garage for a rear end seal so clutch job out even though I fitted one a couple of months ago. So thinking would I be better of upgrading it this time? Which clutches do people recommend? 233 bhp Quote
daniel_g Posted May 16, 2018 Posted May 16, 2018 Exedy 3 puk, slightly hardcore, it wont let you down when you wind that TD04 right up. Miles better than those awful spec 6 puk. Quote
Nilz90 Posted May 16, 2018 Author Posted May 16, 2018 Do you have a link to that is it the Exedy Organic Racing Clutch? Any idea on how the competition stage 4 clutch is? I’m looking for something that would be good for everyday use. Quote
daniel_g Posted May 16, 2018 Posted May 16, 2018 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F150948457296 Paddle clutches are fine for everyday use. Quote
Maxep Posted May 17, 2018 Posted May 17, 2018 Mine started slipping immediately on the standard clutch. Went with the Helix paddle clutch, not bad at all for daily use. Quote
