aaddzz123 Posted May 23, 2018 Posted May 23, 2018 Hiya guys and girls. I'm trying to gain access to my emanage blue unit to check the map and make some adjustments if required but I cannot get it to connect to my laptop for shit. I'm using a USB - TTL adaptor and understand that the original method was to use a serial cable etc. I've tried all variations of software and made sure I had the correct COM port initiated and selected on the software but nothing. I'm also a little unsure on how exactly the TTL USB adaptor is supposed to work. It has 3 lights on there to display power, and I'm assuming that the other two are data sent and data received however the only light to show up when the cables are in the suggested positions, is the main red light for power. If I switch the TX and RX cables around and remove the power cable, all lights will show when plugged into the emanage but turned off. I've tried different drivers too, different launch sequences of the unit and software etc but it always remains offline. I could basically do with a dummy guide on what the lights mean, where the cables go, how to connect this cable properly or check it to make sure it works and the cables are in the right positions and any other advice on getting it connected and working. Any help grateful, cheers. Adam. Quote
akyakapotter Posted May 23, 2018 Posted May 23, 2018 What version of Windows you rocking I'm sure it has to be a really old version to be able to get the software to work. Cheers nick. Quote
aaddzz123 Posted May 23, 2018 Author Posted May 23, 2018 Windows 7. Software itself installs and opens up fine, just won't connect. Quote
gorganl2000 Posted May 24, 2018 Posted May 24, 2018 (edited) Nick may be right...i run emu, and had to buy an old laptop with windows XP to get my car tuned...my prior laptop was Vista, if i remember correctly and that worked as well my newest laptop had windows 7 or 8 on it, and like your experience, i installed the software, but it would not connect via USB to the EMU to allow me to get a tune, it seems the drivers were incompatible-------but it would allow me to view older maps on the hard drive......i even tried some IT advice and ran a partition set up on the newer laptop to install the older windows XP software, but it still didn't work as there was no USB/driver connection when hooked up to the EMU Edited May 24, 2018 by gorganl2000 Quote
aaddzz123 Posted May 24, 2018 Author Posted May 24, 2018 Cheers for the replies guys. I've seen it working in videos on Windows 7 and after researching it, apparently EMU won't work on later operating systems but EMB will? I feel like the issue is probably due to the ttl converter I'm using so I've ordered a different one which I think will be more likely to work. Any other ideas whilst I'm waiting for that to arrive is highly appreciated lol. Quote
Gilly Posted May 27, 2018 Posted May 27, 2018 I have only ever worked with the EMB on windows XP and it ran fine - I bought a netbook years ago for a £70 and for mapping on the road it worked perfectly! Quote
aaddzz123 Posted June 21, 2018 Author Posted June 21, 2018 Just an update guys. I solved the issue by getting a genuine emanage serial cable (actually came with an emanage I bought for another car) and a RS-232 (serial) to USB adaptor. Plugged them together, connected to the ECU and it logged straight up on the emanage support tool. Quote
akyakapotter Posted June 21, 2018 Posted June 21, 2018 Glad you got that sorted nice to no aswell. Quote
