Glanza1996 Posted July 12, 2018 Share Posted July 12, 2018 Were does everyone buy there front wheel bearings from for a Glanza? The reason I ask is because I have had to replace both my front wheel bearings x2 times now within a year and it is really annoying me. I have just recently had both front hub flanges replaced and wheel bearings but the wheel bearing has gone again so this is going to be the third time I have got to replace the front bearing but this time it has only been 5months. Does anyone know why my front wheel bearings keep failing on me I have just been buying them on ebay. Quote Link to post Share on other sites
Calum122 Posted July 12, 2018 Share Posted July 12, 2018 Tracking and alignment done? You're not purposely crashing into pot holes are you? Packing the bearings full of grease with the dust shield? No debris getting in. Quote Link to post Share on other sites
Glanza1996 Posted July 13, 2018 Author Share Posted July 13, 2018 That`s cool I will have a look at getting the tracking & alignment done after fitting a new bearing, Are the bearings from ID-Workz any good? Quote Link to post Share on other sites
Calum122 Posted July 13, 2018 Share Posted July 13, 2018 I think I got mine from Import Car Parts. IIRC they were Koyo, which are obviously decent. Quote Link to post Share on other sites
Idrees Posted July 15, 2018 Share Posted July 15, 2018 Ours are supplied with a 12 month warranty so we'll give you a new one if it packs in (we never get any warranty claims on them though). I suspect there may an underlying issue here though. Quote Link to post Share on other sites
gorganl2000 Posted July 18, 2018 Share Posted July 18, 2018 front wheel bearings tend to last a very long time i'd suggest you check your suspension parts, alignment and/hubs to see if there is any excessive wear/movements Quote Link to post Share on other sites
Glanza1996 Posted July 18, 2018 Author Share Posted July 18, 2018 (edited) I will get all that check thanks gorganl Idrees are your front wheel bearings specifically for a Toyota Glanza or are they just standard starlet wheel bearings? I have ordered a new wheel bearing for the Glanza and I have received the bearing and I have done a quick google of the part number LBK8362 and on one website it does not list Glanza and only says its for a standard starlet is this the reason I could be having issues or are the LPB wheel bearings fine? do all suppliers send Starlet wheel bearings as they are the correct front wheel bearings? Cheers everyone for the help so far Edited July 18, 2018 by Glanza1996 Quote Link to post Share on other sites
