DJ-Alpha Posted November 18, 2018 Posted November 18, 2018 Hi I'm having a real pain removing the cluster to change the bulbs, all but one work. I have removed the surround and unscrewed the cluster. Disconnectrd the left and centre connector. I can't get to the speedo cable or free the other connects. There is very little movement in the cluster! I can't seem to find a detailed step process for doing this! Sorry if I've missed it. Is there a certain order or have I missed something? Any help apprisated. Cheers Quote
5T4R7ET N/A Posted November 18, 2018 Posted November 18, 2018 I remember removing the driver side footwell plastics and getting to it from behind. Its only a few screws, just be careful with the connections if you have any. Quote
Farley V Posted December 1, 2018 Posted December 1, 2018 (edited) To mention on my Glanza there are 3 electrical plug connectors at the top: left, middle and right. Push in the squeezy clip located in the centre of each whilst pulling them out. Then there is a white plastic 'over clip' on the top of the speedo cable in the centre of the clocks, that sits in a notch where it connects into the back of the clocks. Feel it with your fingers. Prise it slightly from one side with your fingers whilst sliding it down and off the speedo cable. Then the cable will come out with a bit of a tug. Then the clocks will be free to remove. Reverse the process when putting back in. Edited March 9, 2020 by Farley V Quote
