H_D Posted February 2, 2019 Posted February 2, 2019 (edited) Got my td04 water lines locally for £50 all in. If you source all the parts yourself it will probably be a bit cheaper. If anyone is making their own you will need the following... 2x m12x1.25 to an6 adaptors 2x 45 degree an6 fittings.An6 braided hose (length varies on different setups)2x an6 hose end finishers. The an6 hose diameter is a touch smaller than the water pipes on the thermostat housing, dip the hose end in hot water for a few mins and they slide on without much force. Edited February 2, 2019 by H_D Quote
bailiff666 Posted December 6, 2020 Posted December 6, 2020 Hi H_D Can you let me know what I need to fabricate oil line and what’s your solution for oil return line Also what’s the lengths of all lines? My turbo is in standard location Quote
H_D Posted December 6, 2020 Author Posted December 6, 2020 4 hours ago, bailiff666 said: Hi H_D Can you let me know what I need to fabricate oil line and what’s your solution for oil return line Also what’s the lengths of all lines? My turbo is in standard location Send me a pic of your set up il have a look for you Quote
bailiff666 Posted December 7, 2020 Posted December 7, 2020 That’s the turbo I will use (with actuator) will be connected with Tuning Development manifold and decat for CT9 so it will be standard location ( same as OEM CT9 ) Quote
H_D Posted December 7, 2020 Author Posted December 7, 2020 (edited) If its for a ct9 that sits in the stock position just use the original oil and water lines. My guide is for a TD04 🤦♂️ Edited December 7, 2020 by H_D Quote
bailiff666 Posted December 7, 2020 Posted December 7, 2020 This is CT9/TD04 hybrid exhaust side is CT9 all rest is TD04 that’s why I need TD04 lines mate Quote
H_D Posted December 7, 2020 Author Posted December 7, 2020 (edited) If its using a ct9 core the fittings are different. If its a td04 core then u need all the bits i mentioned in the original post. Will the oil feed be positioned facing straight up Edited December 7, 2020 by H_D Quote
bailiff666 Posted December 7, 2020 Posted December 7, 2020 Oil feed on the top Water lines on the front Oil return at the bottom Quote
