It’s meant to be for the 02 sensor/lambada sensor.
Without it’ll be pretty poor on fuel but most people claim it shouldn’t affect running
Ok can you buy new lamba sensors to fit?
18 minutes ago, akyakapotter said:
Yep single wire lambda will be needed the wire for it should be up by the thermostat housing. Can get a sensor for eBay tuning developments ect.
Cheers nick
Cheers
what about the other blocked up further down?
1 hour ago, LeonL said:
Could always wire in a wideband gauge using the spare hole
Wide band gauge?? What’s a one of those? Excuse the lack of knowledge
Also know as a AFR (air fuel ratio) gauge. You can get narrow or wide band. Quote from online:
“A narrowband AFR gauge uses your cars stock O2 sensor for data. ... A wideband O2 gaugeuses a much larger voltage range to determine the AFR. A typical wideband will use 0-5V. This allows for much more precision”
See link for examples, can also get other brands such as AEM, there’s always been a long debate on the best brand of gauge.
https://www.innovatemotorsports.com/
Edited by LeonL
