Hi guys had my rocker cover welded with AN- fittings at the time had the baffle removed to make sure it was all clean underneath.do you need the baffle re installed or will it be ok without it.
2 minutes ago, 1990timeismoney said:
That's a good option thank u for the advice.
bare in mind the baffle plate is steel and the rocker cover is aluminum, as long as the baffle has been drilled out properly any competent welder can blob weld it back in for you, I don't like the idea of using screws/bolts as I worry the may start to loosen off after a while which can cause serious engine failure if they fall out
That's a good point.as above I started to drill and tap for holes to use fasteners like washer spring washer with some high strength stud loctite.i to worry about losing a screw but I hope it holds if not it's of to the welders.and rebuilders.
I appreciate your reply and advice.will update with pics once complete.
